Hi i used fossil twist me 1078 previously,i put aside for one and half years now it's not working i don't no what is the problem with it.. please tell me some one now what i need to do.
You can simply replace battery in your Fossil Twist 1114 watch. First of all you have to open back case of your watch and remove existing battery. Be careful and do not creates scratches on the watch. After removing existing battery from watch you should place new battery in the watch.
If you do not wind the watch, and if it is electronic it obviously has a battery. Very possible even with a new watch the battery has run out. This is especially if the watch was sitting for about a year in their inventory before you bought it.
I am not sure if your watch has a kinetic type movement where it charges the watch, or it is purely an electro-mechanical type movement. I did read it has a quartz referenced movement for the mechanical balance wheel. This would certainly involved a battery. If changing the battery is not the fix you would have to send the watch for service.
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
replace the battery? otherwise send it to fossil. regardless of where you bought it it should have a limited 11-year warranty as as i can tell.
http://www.fossil.com/en_US/shop/customer_care/static/fossil-warrantyRepairs.html
mcdevito75 here, Look for any Notch in the cover that match a notch in the case, use a knife with a sharp blade and place the knife in the notch and with a slight twisting motion the cover should pop off. Depending on the age of the watch and the functions cost could be anywhere betwwen $25.00----$60.00 Fossil watches are also collectables.
