RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet Android 4.1, LCD Touchscreen, 800x480, 4 Hours Logo
L
Linda Stevens Posted on Dec 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pad says the internal storage is almost used up...I inserted an sd card, but not sure how to get the tablet to read it so that I'm able to install more apps and games.
Duff Howell
Level 3:
Master:
  • Master 403 Answers
  • Posted on Dec 18, 2015
Duff Howell
Master
Level 3:
Master:
Answers
403
Questions
0
Helped
144929
Points
2213
Good afternoon Linda!
You can view your manual here
RCA RCT6077W2 Manuals . If you go to page 10
RCA RCT6077W2 User Manual Micro usb Headphone Micro Sd it notes a couple of important caveats on the card:
  1. You can use MicroSD or MicroSDHC type cards
  2. Size limit of 32GB
  3. You are warned never to insert or remove the MicroSD card in 'On' mode (i.e. only insert/remove the card when the tablet is off)
Aside from that, it looks like things should work. To be sure on what is the root of the issue, you can:
  1. Insert your card into another device to verify that it works
  2. Format or Re-Format the card - the SD Card association has a formatting app here:
https://www.sdcard.org/downloads/formatter_4
  • Make sure the card is legit. If it was purchased, for instance, off of Ebay, or other not-so-top-tier online store, as likely as not it's a fake made in China, likely with guts from manufacturing rejects. You might, for instance, get a card marked 32Gb that actually has a 2Gb chip in it with a hacked controller that says it's 32Gb. It'll seem to work OK for a few files, and at some point will just write your files into no-where. SD Insight, a free checker app for Android phones can be picked up here
SD Insight Confirm your micro SD card authenticity instantly amongst many options.
Hoping this helps!
D
RCA Delta Pro 2 Won't Read SD Cards
It sounds like the tablet is having trouble reading your 128 GB SD cards.
There are a few things you can try to troubleshoot this issue:
  1. Check the SD card for any visible damage. If the card is physically damaged, it may not work correctly.
  2. Make sure that the SD card is properly inserted into the SD card slot on the tablet. It should fit snugly and be fully inserted.
  3. Check that the SD card is compatible with your tablet. Some tablets can only support SD cards up to a certain capacity or with a certain type of file system.
  4. If the SD card was working fine before and has suddenly stopped working, it's possible that the card has become corrupt. In this case, you may need to format the card to fix the issue.
  5. If none of these steps help, you may need to try a different SD card to see if the issue is with the tablet or the SD card.
I put an sd card into my tablet but my apps does not give me an option to save to sd card. What am i doing wrong. Not good at this stuff so help.
If it's an android, you can change it within an app - like camera. Go into settings and change default storage location from internal storage to sd card.
If the app can't see your sd card, make sure it's "mounted" within your device. Depending on the software version: Go to settings, general, phone/tablet management, storage, from here you should be able to see the sd card. It is either ejected or mounted. Click on the sd card, if you can see the folders content, then it is installed correctly.
Also, if it was used in another device, it may need to be formatted to be used in your tablet. You can do that from the same setting menu.
Hope this helps.
1helpful
I have put 32 gb sd card into excelvan tablet for external storage and its not saving?
Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
How do i get my tablet to read my micro sd card?
Check to be sure the particular SD card is compatible.
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Mounting sd card to a new phoenix hipstreet tablet
Look in Settings/Storage/SD Card and see if you have a Mount option when you insert the card. Make sure the card has gone all the way into the slot and has clicked into place. Make sure the size of the SD card you are inserting is supported by your tablet. (Check the specs in the full manual) If the SD card is larger than what is supported, it may not register with the operating system. Try formatting the SD card on a PC with a card reader and then inserting it into your tablet. (Use FAT32 format).Try another formatted SD card and see if it is recognized by the tablet.
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
I have a pandigital black novel tablet And I And unable to download any apps and all my apps have been erased. And my sd card is not working b c when I try to download a app It tells me that I dont have...
Tablets have internal storage and external SD cards (optional) storage. Apps will download to the internal storage. So under Settings > Storage make sure you have space on your internal storage.
Top RCA Tablets & eReaders Experts
 Mikey
Mikey
k24674
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
