Aspire 4810TZ-4696
SOURCE: bluetooth and IRda in Acer aspire 5320
Click the Start button , click Control Panel, click Printers, and then click Bluetooth Devices. Nearby devices are listed on the Devices tab. First, you must have another Bluetooth device near you, it will not activate alone.
SOURCE: HOW TO ACTIVATE THE BLUETOOTH IN ACER ASPIRE 4730Z
make sure the drivers for the bluetooth are installed, then switch it on.
http://support.acer-euro.com/drivers/downloads.html
if it doesn't turn on make sure you have all the drivers and utility programs installed from the above acer page, then it should turn on.
SOURCE: Activate Bluetooth on Acer Aspire 6530
Dear craigpawlak,
I think the problem you are facing is an issue with drivers.
to ensure this is a problem as I mentioned, follow the following steps:
There
you will see the drivers installed for your PC and see if any hardware
list is accompanied by a question mark that's the hardware driver is
not installed.
Solution to the problem is to install drivers Bluethoot, you may get in the cd when you bought it. if you do not have it, then I'll give the link to get these drivers. (available for Vista and XP). Click here to download driver
How To Install Driver ?
Do not hesitate to contact me if there is a problem or my explanation is less understandable.
regards.
SOURCE: how do i turn on wireless on acer aspire 4810tz
It has a touch panel at the top above the keyboard touch it to turn on also go into the control panel and select wireless devices select wireless you see a wire connection and a wireless connection right click on it select properties and you will see an option to enable or disable enable it an it should come on
SOURCE: I cant connect to the internet, it says enable
You need to go to your control panel then your internet options. From there go to your internet connections and foolow the prompts for wireless connections. That will set up a wireless connection for you, you may have to redo this connection depending on your location when using your computer. Take note unless you know their passwords you can only get on non secure networks. That means be careful what you do for anyone can intercept the work.
