Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
S
Scott Cain Posted on Dec 18, 2015
I have a jenn aire electric cooktop. The fan when the burners are on quit working is this a hazard?
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 19, 2007
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Anonymous
  • 1314 Answers
  • Posted on Dec 30, 2007
SOURCE: jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Anonymous
  • Posted on Feb 08, 2008
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Anonymous
  • Posted on Dec 12, 2008
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
gerbee gomez
  • 222 Answers
  • Posted on Jun 23, 2009
SOURCE: Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
2helpful
One of the four burners does not work. The light comes on but no heat. Can it be repaired?
Yes, you have a bad burner, sensor, burner switch, or wiring problem. The most likely is the burner switch. You should get this repaired asap, as this could be shorting out inside, and cause an electrical shock hazard. Unlikely but enough of a possibility that you should fix it soon.
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
JED 8320 fan and burner switch
http://www.whirlpoolparts.ca/index.php?PHPSESSID=f2330dc59be8bdd5f5463d5e0d1362f9
ONE OF THE FOUR TOUCH PADS DOES NOT RESPOND
JED 8320 Jenn Air Cooktop with down draft. I need a burner switch and a fan switch.
1helpful
2answers
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
1helpful
One of the burners on my Jenn-Air electric cooktop does not turn on and get hot. 3 burners do work. Any suggestions?
the contact may be loose but most likely the burner needs to be replaced. the one you use the most usually goes first, and not getting hot enough is the common indicater of a shot burner
Jenn air fan comes on with rear burners (elec) can I disable?
Perhaps, but sound safety says no. This generates a lot of heat in an enclosed space; the fan may be a nuisance but it is needed to keep the unit from getting too hot. Hope this helps!
Jenn-Air JEC9530 Electric Cooktop fan rattles
When I turn a burner on I don't here the fan run. is this a problem?
2answers
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
4answers
Jenn-air downdraft fan not working
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
