Reasons for generator won't start or does not start correctly:
I Fuel system malfunction, the diesel engine is driven by the starting motor and does not ignite.
II Electrical start system failure
III Insufficient compression pressure in cylinder, fuel injection is normal but does not ignite and there is fuel in the exhaust pipe
IV Injection advance angle premature or too late
V Gas distribution phase is incorrect
VI Environmental temperature is too low
Why My Diesel Generator Set Fail to Start
https://www.dieselgeneratortech.com/generator-sets/Why-My-Diesel-Generator-Set-Fail-to-Start.html
My yardworks portable generator 2150 won't start - Fixya
www.fixya.com/support/t14802132-yardworks_portable_generator_2150
Oct 28, 2012 - First check the circuit breakers on the control/outlet panel. Then take the end off the generator and look at the brushes (usually what breaks) and the ...
Why won't my portable generator start? - Home ...
diy.stackexchange.com/questions/.../why-wont-my-portable-generator-st...
Mar 6, 2013 - The generator is fairly new -- I bought it at the end of June '12. ... An E 3 spark plug is always a good start, Stabil (fuel stabilizer)in the fuel or ...
the generator in parts, accessories - Alberta - Kijiji
www.kijiji.ca > Alberta > cars & vehicles > RVs, campers, trailers
KijijiLittle hours on this generator comes with command start was over $ 500 just for the starter. Yamaha ... Yard Works 2150w generator. Generator starts ... Wanted generator for my camper at least 1500 or more ... You won't see more new motorcycles at one place anywhere else. ... New Champion 4000watt portable generator.
Power Generators New ' Kijiji: Free Classifieds in Alberta ...
www.kijiji.ca/b-alberta/power-generators-new/k0l9003
Kijiji
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
SOURCE: 11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
SOURCE: my 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
