I have a GE Monogram 36" Side by side built in refrigerator with ice maker, I believe model number ZISS360DHSS. Water on floor of Fridge side, usually following evap thaw cycle every couple days. Pulled it all apart and checked for blockage from drain pan through hose to pan under compressor. no blockage. Poured water through with bleach to clean, it flows. Fully thawed and reassembled. Second day (probably first defrost cycle) and the water is back. Help.
the filter is in the upper refrigerator compartment ceiling and is not leaking. The leak only forms every couple days, consistent with the automatic defrost cycle timing.
the water is inside the fridge FYI
