NON FUNCTIONAL ALL LIGHTS BLINKING CONTINUOUSLY E3 ERROR CODE
This did not work for me, I had to try several times and with the play button not the stop button, but thank you it gave me hope, and with sucsess, thank vary much
This method worked for me!! you guys should try this.
i've copy this review from amazon.
by Kane Doerfler
"After a brief power outage from a thunder storm, I also experienced an e3/lights blinking error. I unplugged the phone and plugged it back in several times to no avail. After doing this a couple of times unsuccessfully, I hit the "STOP" button on the base immediately after plugging it in (before it completed booting up to show the "e3 message")and it reset itself and now works fine (or as well as it did prior to the e3). Try it before tossing yours in the garbage"
thanks to Kane. I saved my phone~!!
The solution to E 3 error: Take base unit and put it in freezer until completely frozen, ie. cold soaked. At lease 4 to 6 hours. Then remove from freezer plug telephone line first then power plug. You're problem should be solved.
I can't thank you enough - I tried the re-booting, I tried holding the stop button right after plugging it all back in, everything. I was ready to throw this phone into the trash and decided what the heck? I'll put the base in the freezer overnight and give it one more chance. It is working fine now, thanks!!!!
SOURCE: Panasonic KX-TG2258 with E1 ERROR CODE
I was having that problem after cleaning the base and handset. It seems to resolve itself simply by disconnecting the power supply and possibly the phone input line for several hours. I reconnected my phone and it works again.
My phone worked before I transferred it to another location in the house. No dial tone and gives me an E message.
I hava a Panasonic KX-TG2258 telephone that is not working.
All lights are blinking, and on the display is shown E3 message.
Please let me know what I should do to fix this problem.
Thank you,
CL
Phone flashing with E3 message.....last Panasonic product for me...
I have the same problem just by unplugging for 5 min. Called Panasonic and was told I could get it repaired for $80. + shipping. What a joke!
yes my phone have the same poblems. what do you think about that?
I have the same problem after a power outage.
