Heavy, delicate, quick and heavy lights remain on, not blinking. Turned off power for one minute. Still doesn't run.
SOURCE: Samsung dishwasher flashing heavy light
Anytime a dishwasher stops mid cycle and blinks, it is usually because of clogged drain port, and safety switch prevents next cycle, so just blinks. You will probably see bottom of tub filled with water, and float switch is preventing next cycle which is calling for more water, and obviously there is not enough room, so shuts down next cycle. Remove as much water as you can with wet vac or turkey baster to suck out water, then try and see if cycle starts.
Remove bottom of tub filter, look for drain hole usually at back of tub and see if it is clogged, usually visible at top of drain. Pretty easy to fix, just clean out the area of food waste or broken piece from glass, another common sudden blockage. If you have wet vac, place it over drain hole and cup your hand around nozzle of vac and hole to creat seal and suction to insure clog isn't in drain hose.
Good luck, FREE-BUSINESSES.com
Maybe your heater does not work
thr thermostat will allow the next cycle after water heats
SOURCE: dishwasher blinking light
your owners manual fault guide will tell you what all blinking lights mean ie,,,how many blinks will tell you where the fault lies
