This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist. If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
Place the watch face-down on a flat surface.
Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
Finish removing the pins with your pliers.
Keep the extra links in case you ever need extra room on your watch band.
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
This band is put together with cotter pins. To remove the cotter pins
look at the edge of the band. The end of the pin that comes out is
split and looks like a screw. The end that is solid is the end you want
to push from. Use a small punch to push the pin out. The split end is
the bigger end of the cotter pin so it needs to come out and go back in
the same way it came out. Make sure you remove an even number of links
on each side so the watch sits on the wrist the right way. You also
have a micro adjustment on the clasp. To adjust the clasp simply use a
punch to press the spring bar in the clasp in until it moves. This is a
spring bar so be careful it doesnt jump out if the clasp comes apart.
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
