HP Photosmart 8750 Large-Format Professional Photo Printer Q5747AABA Logo
J
John Scrutchens Posted on Dec 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does printer make a shredding sound as the carriage travels back to the rest position?
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Dec 16, 2015
HP Master
Level 3:
Answers
1124
Questions
Helped
450738
Points
2591
Remove printer covers, locate disc encoder at left side.
The disc encoder stiked with the gear which connected to the motor to step forward/reverse specified by the mother board. If this gear slaked with the shaft( rotating freely)its generates shedder sound. Apply fast glue between gear & shaft to joint them permanently fix.Take care that glue should not fall or run on the encoder barcode print..
To understand better pl find the attached snap.. But performing this activity req.. technical skills..
Best of luck..
Why does printer make a shredding sound as the car - 26009552-acyxr414cgz5ozytj3mwvjdp-1-0.jpg
1helpful
2answers
The Ink carriage in my Epson Printer won't realign from home position to change cartridge, how do I fix this?
If the carriage doesn't move at all, the latch may have gotten stuck. If you unplug the printer, wait a few seconds, plug it in and power on, it should move the carriage back and forth. If it moves at all, quickly unplug it, while it is unlocked.
Now, you can clean around the parked position, and lube the travel shaft (sewing machine oil is good. Any similar light oil is ok).
If this doesn't help, check that the optical tape behind the carriage is clean, there are sensors to measure carriage position, and if the tape gets dirty, they won't work right. Do not use solvents there, you can remove the marks and make your printer into a paper weight.
WHAT IS THE CARRIAGE CARTRIDGE
There are two different types of carriage units that you may be referring to depending upon the model printer you have. Older types of photo printers had two distinct carriages.
1. Carriage referees to equipment that travel left to right in your printer.
2. One is for the print heads that receive ink from your print cartridges and dispenses it to the paper that you are using.
3. The print head carriage that travels back and forth to accept replacement ink cartridges. Most of the time it is tucked to one side or the other and only travels when the printer is opened in a specific way to expose it for ink replacements.
In newer systems the print heads are built into the Ink cartridge, each color has it's own print head.
So in answer to your question the carriage cartridge is more than likely the container that you put your ink cartridge into. Unless you have an older printer and then it would or could be the carriage for either the print head or the ink. They some times need to be replaced. I had to replace that cartridge in an old HP2500 for as long as we had the printer. (4 years). Great machine high maintenance.
1helpful
I stupidly put a new black in cartridge into my epson 1280 printer......backwards.....!!! Now, of course, it won't print Black....AND I can't figure out how to get it out to reverse it. I've pushed the...
Turn on your printer, as soon as the carriage moves out of it's resting position quickly unplugged the printer, the carriage should stop in a postion that you could move it freely by hand. Just position it by hand where you can remove the cartridge and put it back correctly. When your done just gently push the carriage back to it's resting position then put the plug in and turn it on.
1helpful
I had walgreens refill my HP black ink container, but when i put it into the printer (HP deskjet 812c), the ink light just flashed continually and the printer won't work...and it makes these jerky sounds,...
It may be simply resolved by the following steps
1. there is document in the queue but paper is out
2. Cartridge problem (remove and insert again)
3. Communication error
4. Cover is open
BUT as per your description this seems more apt!!
This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON
If its a problem with ink cartridges try these steps
Disconnect the Printer from the Computer.
Press the "Cartridge Change" button for ~ 3 Seconds.
When the Ink Cartridge Carriage travels to the Changing Position PULL THE POWER PLUG (NOT the "OFF" Switch). The Ink Cartridge Carriage should now Slide Freely on the Rail as long as it isn't pushed to the Right so that it goes under the shelf to the "Homed and Locked" Position.
Fold up a Paper Towel (About 1 Sheet) so that its final width is about the same as the width of the gutter under the Print Head on the Carriage and so that it is thick enough when folded to contact and lightly press on the Print Head.
Saturate the folded Paper Towel with ~ 70% Isopropyl Alcohol and lay it in the Gutter.
Manually slide the Carriage and Print Head Over the wet Paper Towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is Correct.
Let the Print Heads rest on the Saturated Paper Towels for a few Minutes or Hours. Too long a Treatment may pull out all of the Cartridge's Ink: Check the Paper Towel Frequently to Assess if Ink is Capillarying out onto the Towel.
When the Treatment appears Successful remove the Paper Towel and Clean Up and plug the Printer power back in.
Run a Test Pattern via the Computer Connection WITHOUT first running the Head Cleaning Utility.
If the pattern isn't OK, Try Running the Head Cleaning Utility to see if it makes it Better or Worse.
If Worse, Repeat the Alcohol Paper Towel Treatment: The Paper Towel may be Gently Pulled back and forth under the Print Heads to wipe them off.
Printer flap is closed but printer says it's not
Open up the door on the printer again. Let the printer carriage (contains the printer ink cartridges) move to the center position. Now you can usually slide the carriage back to the starting position manually. Turn off the printer and allow it to rest. You probably did not harm the printer, but the original starting position was interrupted and needs to be rest. Don't be worried about the sounds, it is only the transfer ribbon making that sound.
2answers
My canon pixma mp 160 not working.apear 5100 error
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi17
4helpful
3answers
Carriage jam
I had this same problem with an HP2355v. There is a carriage directly below the print heads (on the right side of the printer) where the ink is dumped during the cleaning process. The carriage needs to be able to freely move (fore and aft). I noticed that my carriage was really gummed up on the left side of the carriage. I cleaned the edge of the carriage and the channel where it travels with alcohol and qtips. The carriage now moves with minimal effort and the error is fixed! Good luck.
14helpful
3answers
Carriage jam message
I had this same problem and spend hours working on it. Took the side panels apart to get a better look. Nothing anyone said fixed the issue. Not even the link everyone keeps posting to HP's carriage jam fix. Was out of solutions and about to give up and order a new printer. There was one last thing I had to try that I didn't think was going to work, but I had a theory. Right after I tested this solution it started working again. This worked for me, but anyone who has tried every and have not got their printer to work can try it.
My Solution: Open the front covers and look inside. Just above the metal rail that the carriage travels on there is a thin plastic strip about 1/4 in. width and should have a glossy shine to it. I believe this is some kind of positioner. It runs through the carriage and gives it some kind of position. After years of use, it'll become dirty with ink. I used some tissue and alcohol and wiped the strip clean. It worked perfectly fine right after. Below is a picture of the strip I underlined with a yellow line.
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
k24674
Grand Canyon Tech
Grand Canyon Tech
