SOURCE: 50 .2 Fuser Error in
you need an maintenance kit 4100
ACC
C8057A
Maintenance
Kit, Fuser, 110V, LJ 4100
LJ 4100 Series
ACC
C8057-67901
Maintenance
LJ 4100 Series
ACC
C8058A
Maintenance
Kit, Fuser, 220V, LJ 4100
LJ 4100 Series
Selected Item
RG5-5069-000
See RG5-5069-090
Not Available
0
Alternate Item(s)
RG5-5069-090
Fuser Film ***'y, 220V, LJ 4100
180.50
http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
I have a HP LaserJet 5000 with a Fuser Error code 50.1, meaning low temp. I am not a tech, but I have been repairing my own cars, printing presses, computers, printers and anything else that breaks for over 35 years. The previous fuser on my LaserJet 5000 lasted over 7 years and while I was not getting any error codes, it was not fusing laser plates as well as I liked. Until recently I had two HP 5000 LaserJets and was able to trouble shoot by swapping parts. I replace a bad DC controller board in this particular printer about a year ago. Shortly after that I replaced the fuser with a genuine OEM HP fuser and it fused great for nearly a year. A few weeks ago I had a massive paper jam in the fuser and a day later got a Fuser Error 50.1. After checking the Internet I determined it might have broken the ceramic heating element. I swapped fuser with the one in my other identical working printer and the fuser error went away. I swapped the fusers back again and the error returned, pretty much proving the problem is in the fuser. Since I am not made of money I figured I could rebuild a fuser just as well as anyone else so I went on a search for the parts, but it was like calling Area 51 and asking what they were hiding. The service manual indicated some ohms testing to be done on the problem fuser and all results came back showing all the correct readings. I knew the fuser was the cause of the error, and the parts were not cheap so I carefully disassembled the fuser to see if I could isolate the exact part that was broken. The ceramic heating element and everything else looks fine. One detail I had found odd was that the printer used to take a couple of minutes or more to heat up, but I now got the fuser error 50.1 within 15 or 20 seconds of powering it on. This made me wonder if it would even have enough time to heat up enough to know it had a low temp problem. I thought the problem might be in the part that actually measured the temp. While I had the fuser apart I found one small resistor attached to the frame directly under the main drive gear. I did an ohms test on the resistor and it showed bad. I really hate to tear my good fuser apart to swap the resistors for fear I might burn it up to, so has anyone out there heard of a bad resistor causing a 50.1 error? I found only one reference on one site about a different LaserJet with a 50.1 code because of a bad resistor, and I have no idea where that resistor is on that particular printer. I know I could have just replaced the fuser by now, but I like to learn how things work and solve puzzles like this one. I am hoping some of my info may be of help to someone and if anyone has anyone ideas or thoughts on my comments, I would love to hear them. I will go on a search for a resistor next week and see if that helps. I hope to hear from someone soon. Thanks and God bless. James
SOURCE: I Have HP Laserjet 3055
You can reseat the fuser or you will have to replace the fuser. Please note the these machines the fuser is located in the middle of the machine. Most likley it's a bad fuser.
SOURCE: how to reset hp laserjet m1319f mfp fuser? Help.
Here is the screen shot from the service manual
If you need the complete refernece on how to complete this job let me know I can get the manual uploaded in about 45 minutes. As I have to get to a service call.
