Kyocera FS-1128MFP FS-1128MFP Multi-Function Printer with Prin Logo
Kenneth Alexander Posted on Dec 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
New AT&T line will allow reception but not sending. HP color MFP next to it works fine.
Claude Kayser
Level 3:
Top Expert:
  • Kyocera Master 9,098 Answers
  • Posted on Dec 15, 2015
Claude Kayser
Kyocera Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061486
Points
28436
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Testimonial: "Sorry I may not have been very clear, I need the actual button sequence to access settings. I have found out that the admin code is '2800' but not how to get to where it is input. Thanks again."
  • Claude Kayser
    Claude Kayser Dec 15, 2015
    That's all I found on the WEB, good luck.
2helpful
2answers
Hi my HP printer fax was working fine but now I am getting a 351 error message I rang the fax print test and everything seemed fine there
    1. On the product control panel, press the setup button (c01661990.gif ).
    2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
    3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OKbutton (c01335940.jpg ).
    4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
    5. If the ECM is off try turning it back On
    6. Check All these other settings
    7. Press the Setup button c01661990.gif Go to Advanced fax settings and check if the Fax speed is set to medium
          3helpful
          2answers
          I cant find out how to turn off error correction mode
          Turning off ECM / lowering baud rate, neither will matter. Fax machines are ANALOG devices. MagicJack, Vonage, DSL are DIGITAL phone lines.
          Your fax machine will not wot work reliably.
          1helpful
          2answers
          Fax feature in HP PCS 950
          Try switching the dialing mode to "Pulse" and lowering the baud rate for the printer.
          Sending fax
          Wow. Digital lines are difficult to fax over. Most are still set to use analogue lines.
          Those are also very odd changes. Most fax machines no longer even have a setting as low as 9600 baud.
          Your fax may not have the ECM mode as changable, may just be built in, but that is not a function you normally would want to turn off. ECM is Error Correction Mode.
          This honestly just sounds like a disclaimer to excuse their system's poor fax service.
          Baud rate
          # Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
          1. Press the Fax button, then press Options untill it gets to ADVANCED FAX.
          2. Press Select.
          3. Press Options untill it getsl MAX SEND SPEED appears on the LCD display.
          4. Change it to 9600 BPS using the - (left arrow) button.
          5. Press Select.
          # Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
          1. Press the Fax button, then press Option untill it gets to ADVANCED FAX.
          2. Press Select.
          3. Press Options until ERROR CORRECTION appears on the LCD display.
          4. Change the setting from On to Off using the + (right arrow) button.
          5. Press Select.
          Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes.
          Sending Fax
          set baud rate to 9600 or slow
          set resolution to standard
          set error correction mode (ECM) off
          if fax has overseas mode turn it on
          vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
          Sending fax
          changing these settings:
          ECM-error correction 'off'
          V.34 'off'
          Silence Detection 'on'
          Top Kyocera Office Equipment & Supplies Experts
          ZJ Limited
          ZJ Limited
          Grand Canyon Tech
          Grand Canyon Tech
          Ngoro
          Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
