Tablets & eReaders Logo
Danae Cushway Posted on Dec 14, 2015
I can't turn on hip street flare 2 tablet. When i plug into charge I have no symbol my screen is black. Ive tried different plug ins through out the house and nothing. What's wrong with my tablet?
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Flare 3 tablet will not turn on
TRY HOLDING VOLUME CONTROL AND ON BUTTON AT THE SAME TIME ... RESET MENU SHOULD COME ON SCREEN
How do I recover space from internal memory on restored Hip street Flare 2? NOT looking to restore lost content, only reclaim "lost/missing" memory space...cannot install anything at all, after factor
If you have done several factory restores, then the internal memory chip is probably damaged and not reading its full capacity.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
What does it mean when the charging light is flashing when charging
Blinking white simply means the tablet is communicating with the internet, checking mail, updating news, weather, etc.
Try to run the tablet down to the 2% warning, then plug it in and charge till it is full.
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Loading issues
how do i get my per loaded games back on my kurio 4s
Hi I am locked out of my hips street flare tablet , I recovered my password but it still doesn't accept it, help
Go into setup and rest to factory settings and start over should be in the settings part of tablet
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
