Install a brand new needle. The old needle may be bent, dull, or defective.
Use the correct needle and thread suitable for the fabric you are sewing. All About Needles
Use only good quality thread, not old or bargain bin thread.
Rethread the machine from the very beginning. BE SURE to RAISE the presser foot BEFORE threading the upper thread so it will seat properly in the tension disks. Check that all the steps in the threading process have been followed.
Do not pull or push the fabric through the machine, Guide it lightly to keep it going straight but let the machine pull it through.
Check to make sure there are no pieces of thread or lint in the bobbin area.
Check pages 114 & 115 of the owner's manual:
http://www.manualslib.com/manual/504973/Pfaff-Expression-2034.html#product-expression%202044
If it continues to skip stitches or sew unevenly, it may need repair service. Could be a timing issue or something is loose.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
SOURCE: Kenmore sewing machine - uneven top stitches
Am about to buy this machine for my wife and the sewing machine cabinet I have chosen has parameters as far as the overall dimensions of the machine. Can you provide me with the width, depth and height of this sewing machine. The cabinet is offered for sale by Sears so it ought to work but still I will feel better with this information. Thank you.
SOURCE: Blind hemmer
First get a new quality needle of the right size for your machine use a good quality hemming thread and check your tensions. If this fails to fix the problem you will probably have to have the timing checked.
SOURCE: How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
SOURCE: trying to sew straight stitch but stitch loose and...
No top tension, follow manual to thread top again and make sure tension dial is set to 5 and thread is pulled between the tension discs fully.
