The KERNEL_DATA_INPAGE_ERROR bug check has a value of 0x0000007A.
This bug check indicates that the requested page of kernel data from
the paging file could not be read into memory.
Parameters
The four parameters that are listed in the message can have three
possible meanings. If the first parameter is 1 or 2, or 3 and the third
parameter is 0, the parameters have the following definitions.
Parameter
Description
The lock type that was held (1, 2, or 3)
The error status (usually an I/O status code)
If Lock Type is 1: the current process
If Lock Type is 2 or 3: 0
The virtual address that could not be paged into memory
If the first parameter is 3 (and the third parameter is nonzero) or 4, the parameters have the following definitions.
Parameter
Description
The lock type that was held (3 or 4)
The error status (typically an I/O status code)
The address of the InPageSupport structure
The faulting address
Otherwise, the parameters have the following definitions.
Parameter
Description
The address of the page table entry (PTE)
The PTE contents
Cause
Frequently, you can determine the cause of the
KERNEL_DATA_INPAGE_ERROR bug check from the error status (Parameter 2).
Some common status codes include the following:
- 0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
- 0xC000009C, or STATUS_DEVICE_DATA_ERROR, typically indicates bad blocks (sectors) on the hard disk.
- 0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or
loose cabling, termination, or that the controller does not see the
hard disk.
- 0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
- 0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper
termination or defective cabling on SCSI devices or that two devices
are trying to use the same IRQ.
These status codes are the most common ones that have specific
causes. For more information about other possible status codes that can
be returned, see the
Ntstatus.h file in the Microsoft Windows Driver Kit (WDK).
Another common cause of this error message is defective hardware or failing RAM.
A virus infection can also cause this bug check.
Resolving the Problem
Resolving a bad block problem: An I/O status code of
0xC000009C or 0xC000016A typically indicates that the data could not be
read from the disk because of a bad block (sector). If you can restart
the computer after the error, Autochk runs automatically and attempts
to map the bad sector to prevent it from being used anymore.
If Autochk does not scan the hard disk for errors, you can manually start the disk scanner. Run
Chkdsk /f /r
on the system partition. You must restart the computer before the disk
scan begins. If you cannot start the computer because of the error, use
the Recovery Console and run
Chkdsk /r.
Warning If your system partition is
formatted with the FAT file system, the long file names that the
Windows operating system uses might be damaged if you use Scandisk or
another MS-DOS-based hard disk tool to verify the integrity of your
hard disk from MS-DOS. Always use the version of Chkdsk that matches
your version of Windows.
Resolving a defective hardware problem: If the I/O status is C0000185 and the paging file is on an SCSI disk, check the disk cabling and SCSI termination for problems.
Resolving a failing RAM problem: Run the hardware
diagnostics that the system manufacturer supplies, especially the
memory scanner. For more information about these procedures, see the
owner's manual for your computer.
Check that all the adapter cards in the computer are properly
seated. Use an ink eraser or an electrical contact treatment, available
at electronics supply stores, to ensure adapter card contacts are clean.
Check the System Log in Event Viewer for additional error messages
that might help identify the device that is causing the error. You can
also disable memory caching of the BIOS to try to resolve this error.
Make sure that the latest Windows Service Pack is installed.
If the preceding steps do not resolve the error, take the system
motherboard to a repair facility for diagnostic testing. A crack, a
scratched trace, or a defective component on the motherboard can cause
this error.
Resolving a virus infection: Check your computer for
viruses by using any up-to-date, commercial virus scanning software
that examines the Master Boot Record of the hard disk. All Windows file
systems can be infected by viruses.
