From the bottom there should be a couple of screws to hold the base on. If they are not there then you need to remove the concealment panel at the base where the stand goes in. Once that is off you will see 3 or 4 screws holding it on.
Please check ebay and amazon for the replacement base/stand. If not available, you can reach out to your local Target or Bestbuy to see if they have anything in their catalogs.
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's. https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
if its remote control try pressing no 1 and see if it comes on.alternatively the on and off switch if faulty on th tv,but the remote control should still switch it on.also switch off the tv for 24 hours by completely removing it from the mains and see if that resets it.
ricch
Just called the company and was told that you simply remove the 4 screws on the back of the stand that is holding it to the tv....They do NOT recommend mounting the TV because it will make your warranty ineffective-per the rep.
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
