Its is not working properly How do I replace it because it has Lifetime Warranty
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Testimonial: "Sound advice."
SOURCE: looking for replacement arm cuff for my sunbeam
To get a replacement arm cuff call sunbeam at 1-800-394-2326
The cuff will cost you 12.95 there. If you need you can get the manual and order sheat on the link below. Page 10 of manual.
http://www.foodsaver.com/manuals/HAH/Manuals/7652.pdf
Good Luck
Testimonial: "i messed up you fix me thanks very much"
SOURCE: I need the instructions for
You are spot on. It is a possible indicator for Atrial Fibrillation or AFIB. If you suspect that you have AFIB, you need to get your doctor to prescribe a digixon product, AFIB is very dibilitating and can cause death. Take care and seek help.... Guy
SOURCE: how do you set the
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped.
Thank you
SOURCE: Where can I get a replacement cuff for our Sunbeam
need a cuff for model 7650 sunbean blood pressure monitor. where can I purchase one?
