Optoma HD8000 LV Manuals
http://www.manualslib.com/products/Optoma-Hd8000-Lv-615409.html
SOURCE: RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the "0000H" on the bottom left of screen...that's how mine worked today.
SOURCE: SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
