Hampton Technologies Brinks Timer Logo
t
thomas connor Posted on Dec 08, 2015
How do you turn on a brinks grounded 24-hour mechanical timer
Should the switch be on outlet on or timer on?
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Nov 27, 2010
SOURCE: BRINKS MODEL 42-1020 A 24-HOUR TIMER WITH 15-
Not sure what your problem is exactly....is it not working? You don't know how to set it???
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Timer GE15119 should the lamp be on when you plug the timer into the wall outlet ?
It is a very basic mechanical timer. I have 3 of them.
Remove it from the wall.
Pull the tabs up for Off and Push tabs down for On.
Set the Time by turning the dial, time to arrow.
Set the slide switch to Timer On.
Plug in the appliance.
Plug the timer into the wall socket.
Manual and Advertising is here.
GE 15119 Manual - Waterheatertimer.org
http://waterheatertimer.org > pdf > GE15119-Man...
PDF GE 15119 timer manual http://waterheatertimer.org/How-to-set-timers.html http://waterheatertimer.org/GE-timers-and-manuals.html#52012.
GE 15119 Indoor 24-Hour One-Outlet Plug-in Basic Timer ...
https://www.toolboxsupply.com > products > ge-15119...
GE Indoor 24-Hour Mechanical Timer is an easy-to-use basic timer. Ideal for lamps, seasonal lights and portable fans. Turns a lamp on/off at desired times daily, ...
Brinks timer 44-1030 .
Reset the timer, and reprogram.
Do not exceed the 500 watt incandescent maximum
Test outlet for correct polarity and grounding using circuit analyzer.
Try timer on different outlet and different load.
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
Buy another $$12 timer from Walmart and return defective timer in new package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
How do you use a brinks mechanical timer 42-1020? I have figured out what all parts are just don't understand how to use the pins??
Brinks 42-1020 is analog timer with 48 segments (pins) located around edge of dial.
Each segment (pin) represents 15 minutes in 24 hour day.
Segments on this timer push down and outward.
Open following links for instruction illustrations:
http://waterheatertimer.org/pdf/Brinks-42-1020-manual.pdf
The Brinks Model 42-1014 fails after a few weeks. The motor that turns the timer dial is not strong enought to trigger the on switch. I can move the dial by hand to turn it on and it does turn off but...
I agree.
I test timers.
Brinks timers are near lowest quality of all timer brands, yet all timer manufactures sell lower end products to meet price points. Brinks are probably made by one of the bigger brands.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Test your outlet with cheap circuit analyzer from box store to make sure that polarity of outlet is not reversed. Notice that Brinks timers, like most plug-in timers, have polarized plug.
Polarized plug has wide and narrow blades so they plug into outlet correctly.
Wide blade is for Neutral, and narrow blade is for Hot.
If outlet has polarity reversed, this will adversely affect timer motors, and other appliances.
4helpful
2answers
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Turn lamp ON. Make sure bulb is good.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
Add a comment for more free help.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
2helpful
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
1helpful
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Top Hampton Technologies Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
