Model wasnt among those on there website just trying to download music pc wont recognize mp3 player
SOURCE: No owner's manual
You can download the manual from the link below: http://www.gpx.com/shop_ind.php?id=344# Click on the "Download Center" link on the left. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: GPX MW6815DT trouble
For those that still use this mp3 player here are some things you need to know.
the gpx mw6815dt can operate as a media player or a usb storage device.
you need to change which state it is in via the System option.
Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
Note: DRM only works when the gpx is in Media mode.
If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
SOURCE: Loading music on gpx mp3 player
go to poilit or some your commfortable with. down load to pc the stuff u want, then move this to your windows media center plug mp3 to your pc. then open media center it will ask download to device or cd clik device and it will do the rwest
SOURCE: Missing driver for sony mp3 NWZ-B135F
What is the operating system ofy our computer? If running XP, it will use the built in driver of XP so you just need to install this device automatically
