The best thing to clean an oven or anything of the sort is to use easy-off oven cleaner... Spray on and leave sit for 15 mins wipe off with dry rag (or medium- fine steel wool if needed) then rinse with wet rag, make sure to rinse all the chemicals off before using it... Also this works great on car rims getting brake dust off "spray on wait til it turns purple blueish then spray with hose." NOTICE - In either case if there are any plastic parts do a spot check on a inconspicuous spot first, because it might bleach the plastic "turn it white".......... The picture is the exact kind that i use for both my oven and rims on my car
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
heatman101
