There's not much difference except in the pressures of the gasses. The PROPANE must have a round attachment that controls the pressure of the gas, is inline, usually close to the tank. On the top of that device, valve, is a screw-type mechanism, often covered by a flat piece of plastic that can be gently pried off. If you research, you'll find how much to turn that set screw, and in what direction. It's quite easy.
