Hitachi Deere Excavator Center Joint / Rotary Manifold ...
? 10:00
https://www.youtube.com/watch?v=Vsd_Os6WFCw
Mar 12, 2013 - Uploaded by woodieswood
Hitachi Deere Excavator Center Joint / Rotary Manifold Rebuild ... my Hitachi landy swing brake keeps ...
Viewing a thread - Hitachi Excavator- Swing motor gearbox leak ...
talk.newagtalk.com/forums/thread-view.asp?tid=362837...flat...1
Jan 30, 2013 - 3 posts - 3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
SOURCE: I have a coolant leak on my 1994 Cadillac Deville.
Yes this models tend to do that, check the coolant mixture after repair, yes is a diy proyect but you at least will have basic mechanic abilities to perform this, make sure you mark all the hoses and cables when dismantling.
SOURCE: had a mechanic try to fix exhaust leak @ manifold,
If you think that the angled stud is stopping the manifold tightening enough to seal, an extra gasket could possibly fix the leak. If possible it would be better to **** the hole in the manifold so that it could pull up tighter on one gasket.
SOURCE: antifreeze leak from cracked intake manifold ?
There are aftermarket ones avaliable that are cheaper than the dealer, but of cousre the quality is less. , check DORMAN PRODUCTS
SOURCE: what & where is the "air conditioning manifold hose"?
it's two little hoses in on the left part of the engine running towards the front. You probably need to replace them and put refrigerant back in. not soemthing you can do by yourself.
