SOURCE: Dell 1710 lights
You need to replace the drum and toner to correct the issue. That's the sign of the drum at its end of life.
SOURCE: Toner not printing on right side of paper
hello! It sounds like the imaging drum is damaged. In some toner carts (especially by HP) they have the drum built right in the cart. And when a new cartridge is installed and when they are replaced can rule out a bad drum. In this case It must be separate. You should be able to remove the image drum and inspect it. Just don't touch the drum with bare hands! This can also be a symptom of three other things. It can also be the drum that heats the toner onto the paper. It could be dirty and that is tricky to repair along with the fact is that toner could be being scraped off the paper before being hardened as well. This line streak can be traced to a foreign material in beween the pinch rollers, it is a good idea to see if a piece of ripped paper is stuck inside. Finally, it could be electronic failure with the laser module; scanning electronics. That is bad news!
SOURCE: Recently changed the black toner cartridge in the
Replacing the toner cartridge should fix the problem.
