SOURCE: Maytag Neptune front load will turn on then off in 3 seconds....
hi there,
please supply the full model # on your washer.
SOURCE: Front load washer shakes violently during spin cycle
I had this problem as well.
I called dealer and Maytag.
They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad.
It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer.
Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
SOURCE: My maytag neptune front load washer displayed ND
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
SOURCE: My Maytag Neptune front load washer continues to fill with water.
For troubleshooting assistance please click on the following link
http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
