The grinder seems to be making a squeaker noise when grinding beans. Is there a maintence step like greasing it to fix this?
SOURCE: Grinder will not turn off!!
It can be the micro switch in the machine you have to replace.
If you take off the top you will see it where the hole for the beans are.
SOURCE: Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
SOURCE: Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
SOURCE: when i turn the machine
Generally, coffee beans are oily and form a goo in these machines. You may get lucky by first unplugging the machine, getting some copper wire (#14 or #12) and poking around in there to loosen the crud up. If this doesn't work, the unit will have to be disassembled and cleaned. Messy!
