Question about Sewing Machines
Where is reverse button - Sewing Machines
  • jhnolson Dec 04, 2015
    Hi jessie anderson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    We need make and model
    Thanks
  • Sewing Machines Master
  • 12,731 Answers
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
sewing machine reverse Google Search
Posted on Dec 04, 2015
6ya staff
SOURCE:
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
Reverse not working. Pressing the reverse button isn't engaging the machine in reverse - the light has gradually stopped coming on, it appears to be disconnected.
take your machine to a Viking dealer and have them check it out. it probably has a worn 8 button keypad. the reverse button is usually the first to wear out. this not a DIY project.
Mar 10, 2015 | Husqvarna Designer I
My singer 4210 will only work in reverse
The reverse button may have loosened check for looseness and tighten if possible
Oct 30, 2014 | Singer Inspiration 4210 Mechanical Sewing...
Reverse button broken
the reverse button that makes the machine sew in reverse is not the feed dog, the feed dog is in the needle plate area. under the needle
when the reverse button is broken the machine must be taken apart and another put in it's place, at a sewing machine repair shop.
Mar 04, 2014 | Euro-Pro Sewing Machines
Husqvarna Classic 100 sew machine , pressed reverse button, now it sew reverse only!!! Please help! i pressed, i hold, turned off and on, nothing....... any ideas?
There is a permanent reverse position on the dial button behind the reverse where the stitch length is located. Check to see if you have positioned the knob to permanent reverse. The setting looks like a "U" turn arrow.
Feb 18, 2011 | Husqvarna Scandinavia 100 Sewing Machine
Ny bernina 1090 will only sew in reverse
My bernina did this too. Put your finger on the reverse stitch button, and keep it there for a few seconds. You have pressed the reverse stitch button too long, and it has gone into reverse mode. Hope this helps. tich
Oct 09, 2010 | Bernina 1008
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
202 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
