White dots appear on the screen especially in black
SOURCE: SAMSUNG TV
Possible bad color wheel..need lamp code # to get correct
wheel part #.........................................T.
SOURCE: samsund rear projection tv
I hate to tell you this but its a good chance its your light engine,if the dots begin to spread over the TV it is the Light engine.
SOURCE: hls 5065 samsung rear projection tv
This could actually be an issue with either your DMD board or your Video board. With the TV on, select your menu, if the white dots are still there, the issue will be with the DMD board, but if they don't appear on the menu, the issue would be with the Video board.
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
SOURCE: samsung dlp tv. white dots scattered across the
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
