You cant operate tally with the other version data of tally
you will have to migrate the data
the migration data option is there in tally
i want to step by step more clearly
Restore Data
• In the Company Info menu select Restore
The Select Companies to Restore screen appears
• In the Destination enter the path of the folder where the backup has to be restored.
• In the Source enter the path of the folder/drive where the backup is stored.
• Select the required company from the List of Companies displayed
• Press Enter to restore the backup in the specified folder
Migrate Data
• Start Tally.ERP 9
• Tally.ER9 will commence the process of logically migrating the data to Tally.ERP 9
IN STARTUP MENU WHILE SELECTING ACTIVATE LICENSE,IT SHOWS INCORRECT DATA,RUN ONLY IN VERSION 10.CAN U PLS TEL ME HOW TO TO SOLVE THE PROBLEM
please use migration utility
"IN STARTUP MENU WHILE SELECTING ACTIVATE LICENSE,IT SHOWS INCORRECT DATA,RUN ONLY IN VERSION 10.CAN U PLS TEL ME HOW TO TO SOLVE THE PROBLEM" my suggestion is first you change the data location in tally.ini file which is in your installed location then you have to try to activate the tally and after activating the tally you can Rechanged the Data location and rewrite the same
Suggestion of Joslyn Dsouza is best, i try and success, thank you Joslyn Dsouza
You can try Rewriting the tally data..
