I had the same problem. I opened up the unit and gently released the tray from inside. It has been working fine since - except for the problem I just posted i.e. the remote does not work.
There should be a small hole on the right side bottom of the tray.....take a paper clip and insert it in the hole....while pushing the eject button...it should open then.....let me know if i helped you.
Hi, The default password is 1234. or.. Memorex MVD 2037 & Memorex MVD 2051
1. Turn on the Player.
2. Press the Open / Close button, (keep tray open)
3. Press the Clear button.
4. Press 1,3,6,9.
5. Press the Region you want, 0 for Region free.1 for Region 1 and so on
6. Turn your player off and then back on.
N.B if the hack does not work you may find you have to ommit step 3 and try again.so the hack will be
1.Turn on the Player
2.Press the Open / Close button , (keep tray open)
3.Press 1,3,6,9
4.Press the button for the Region you want, 0 for Region free, 1 for Region 1 and so on.
5.Turn your player off and then back on. Alex
The MVD2027 has a bit of a reputation for being really picky about which discs it will play. It's often especially poor with recordable DVD's, and especially with rewritable discs. This kind of behaviour can also be an early sign of a failing laser head assembly.
All you can do is to try the movie recorded onto different brands of recordable dvd and also see whether it makes any difference using DVD+R or DVD-R. Other than that, there's nothing else you can do.
my problem is I want my laptop atualisar has 32mb Hasan xp and I want a CD and I can not put a program she is more modern windows 98 am programs and not the camera is not compatible for grabs if I can help as atualisar thanks
time to upgrade not even worth it or to find parts sound like bad controller old ok samsung upconverting one 89 bucks circuit city k betifull picture thx nick
Yes, I still need a solution to this problem.
