GPS Logo
J
Jimmy Scaf Posted on Dec 01, 2015
I have a six year old Navigon unit that I never used. How do I cancel directions and reset to a new direction?
1helpful
2answers
The gps sreen is disable and i cannot inter letter, number or touch the icon in the screen
My name is Mike, I am a GPS expert. A lot of your problem is updating issues, and rebooting issue. Please read all this information below. Thanks So Much, Here is some of my personal experiences, Sense I am also paid to test new units that hit the market through manufacturers.
Update: September 8, 2011: Navigon was taken over by Garmin. There are NO MORE USA MAP UPDATES for this unit. If you buy it you will NOT be able to update the USA maps.
I'm terrible with directions so I bought this hoping it would help me and it did. It found the satellites immediately and kept me moving along quickly. It updates quickly and even if you choose a different route it recalculates a new route and maps it out instantly. The touch screen is responsive and easy to use. It's well made and doesn't feel cheap. The windshield mount works easily and holds the unit in place.
When you register the unit at the Navigon website, you'll find out that a software update is not necessary as of today. FreshMaps is supposed to be available this month (July) and you can sign up for E-mail notification as to when they'll be ready for download. The unit comes with a 2 gig memory card and you can install a larger one when it's needed. The operating system for the mapping program is Windows CE. No problems with it yet.
So far, I'm happy with this unit. It does what I need without a load of unnecessary bells and whistles.
August 3, 2008: As of today, FreshMaps update is now available for this unit. Just go to the Navigon website, log into your account and download the Navigon downloader program. Install the program on your computer and you're ready to go. You can even backup your old maps with this downloader program which is recommended before you download the new maps and install them.
October 1, 2008: Navigon now gives you FREE lifetime traffic information. You just can't go wrong. I've been very happy with this unit.
HERE IS SOME MORE COMPUTER BORING INFORMATION TOO:
The Navigon models, like many competitors, use a customized version of Microsoft's Windows CE as their basic operating system - augmented by a software package which includes the Map information, Points Of Interest, and the manufacturer's particular 'twist' on a User Interface (what you deal with, onscreen, to enter information and use the device). The Navigon units use a 2GB SD Memory Card to hold it all - which allows for an easy hardware upgrade (pop in a bigger Card) if the data-handling needs ever grow beyond 2GB. (In comparison, my ancient Garmin had a 32MB internal chip, and wasn't expandable.)
BOTTOM LINE, IS YOU NEED TO TURN POWER OFF, AND AS YOU TURN IT ON, HOLD ON BUTTON ALL THE WAY THROUGH BOOT UP UNTIL IT TURNS COMPLETELY ON THEN RELEASE ON BUTTON. IF THIS MANUAL REBOOT PROCESS DOES NOT WORK, NEED TO UPDATE UNIT.
I HOPE THIS HELPS, MIKE, FROM FIXYA
also to contact me for future problems, check out my direct market place site through fixya for other areas I am a expert in. Thanks Again, Mike
http://beta.fixya.com/users/mc1bean
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
2helpful
2answers
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
How do I sync my phone to my navigon?
put phone in discoverable mode then on gps go to bluetooth and new conection. when gps finds phone click on it and pair the devices.
1helpful
CAn't set the clock on Navigon 2000s GPS
Caution! Selecting the (Cancel) button during these steps will cause the
NAVIGON device to cease operation and will require the user to reset the device.
First Time Startup
When you first start your device, the LANGUAGE SELECTION WINDOW displays.
1. Select the appropriate language and tap OK.
The DISTANCE UNIT SELECTION WINDOW displays.
2. Select either Kilometers or Miles and tap OK.
The CLOCK SETTING WINDOW displays.
3. Select either 12h (am/pm) or 24h and tap OK.
The selected options will be used by the device.
did you try reset to get back to the first time setup as posted above?
2answers
Navigon 7100 Fatal Application Error
I had the same problem with my unit.
Did you try to reload ALL the files back to the memory card?
This as a slow process,but it seems to go a little faster if you use a card reader.
Format card using FAT option,not FAT32.
Hope this helps
13helpful
2answers
Navigon 5100 won't turn on when battery is charged.
try holding the power button down for 15 to 20 seconds - that worked for mine!
Hope that helps
2helpful
2answers
Navigon 2100 problem
2 things that might help...use a paperclip and press the reset button (small hole on side, you'll feel a click) hold it for 5 seconds. THEN hold down the power on button for over 10 secs (keep holding while it shows version number) and it will perform a factory reset. You will possibly lose any settings and addresses, but better that than a locked GPS unit.
Old unit not powering on
Hold down the power button and push the reset button. Then select the corresponding cancel button (unless you want to loose everything. If that doesn't work, pull the battery and the backup battery. You will loose everything but it might bring it back to life.
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
