Televison & Video Logo
A
Anonymous Posted on Dec 01, 2015
There is no TV button to press on rc-017 remote, setup instructions say press on tv button till led lights up.
Batteries new and good
Level 3:
  • Televison & ... Master 6,688 Answers
  • Posted on Dec 01, 2015
Cindy  Wells
Level 3:
Answers
6688
Questions
0
Helped
3532370
Points
21745
If you mean the Coby RC-017 remote, it is not a universal remote that can be set to control any TV or other device. This remote will only work with the TV for which it was originally programmed. I believe it should work for a TF-TV1511, if both the remote transmitter and television IR sensor are working. Assuming you have the correct TV, try just pressing the power button.
I hope this helps.
(I suspect you found the directions for the Coby Universal Replacement Remote which controls several devices.)
Testimonial: "I suspect you might be right but I have never heard of Vizio before so I don't know how I came up with that name unless it was on the invoice. Also there is no name on it but there are 'V' symbols front and back.?????????????????"
  • Cindy Wells Dec 02, 2015
    Vizio is another vendor of various electronics. They have a keyboard remote, XRT300, that ships from some vendors with a RC-017 (or RC-015) sticker on it to protect the logo. It works with a number of their TVs, including the M420SV. The sticker can be removed. It is a similar pre-programmed remote that is locked to specific compatible TVs. Cindy Wells
1helpful
Tryin to conect cox remote to my onn tv but the code isn’t working
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV:
1 – Turn ON the TV you will be using with the XR11 remote.
2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red.
3 – Begin manual TV code search by entering 991 on the XR11 remote.
4 – The LED status light will flash Green 2 times.
5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes.
6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF.
7 – After your TV turns OFF press SETUP.
8 – The LED status light on your remote should flash Green 2 times.
9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed.
Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
4answers
A Magnavox TV was purchased by my sister at WalMart a couple of months ago. The Model Number is CT270MW8A. My sister and I are unable to get any Code we find in instructions/guides to program a Direct TV...
The following code is the most popular for your brand. 10054
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • 0helpful
    MY TV REMOTE SUDDENLY STOPPED WORKING WHAT COULD BE THE PROBLEM
    Reprogram!
    HOW TO PROGRAM Remote Control DOING CODE SEARCH
    1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
    I can't program my remote control for TV Sony. Due to I lost the manual. Can you help me plase? Remote control RC 23 Direct tv.
    try this: 10000 findmorecodesoff.gif itworks2.gif
    Setup Instructions
  • 12helpful
    2answers
    RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
    the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
    1) Make sure the tv is on.
    2) Press and hold the set up button till the red light on the left hand corner stays on.
    3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
    4) Then enter one of the four digit codes and the red light will turn off.
    5) Then press channel up.
    If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
    6) press and release mute to install the code. The light will go off.
    Program remote to tv
    JVC tv codes0463...0053...1 turn on device 2 aim contrllr at device and press TVkey for TV 3/press and hold little 'p' key upper right on contrllr, till LED blinks twice, the release 'p' key 4. enter in first set of code numbers 4-digit code, if this is right set LED will blink 2x. If not repeat steps, till LED blinks twice after entering 4-digit code....then press the power button...the device should turn off and your good to go. Just make sure when you go to operate your remote that you have the right device button turned on.
    Rca universal remote
    http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
    If none of the codes work then we have two other solutions:
    1. Searching For Your Code
    If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
    If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
    1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
    2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
    3. ENTER 9-9-1 (two blinks on the remote)
    4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
      Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
    5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
    2. Learn the buttons from the original
    Line up your original remote and the head-to-head before completing thefollowing steps.
    1. PRESS and HOLD the SETUP button until the red LED flashes twice.
    2. PRESS 9 - 7 - 5, the red LED will flash twice.
    3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
    4. PRESS the button that will receive the learned function, the LED will flash rapidly.
    5. PRESS the button on the original remote to be learned.
    Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
    To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
    More help for programming your remote can be found here:
    http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
    Hope that helps! Should you have any further questions,please feel free to post them here.
    Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
    · Set the "Mode Switch" to TV.
    · Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
    · Enter the 5 digit Code above.
    · Try your new code and tell us how it worked!
    You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
    hope this may help;
    Regards,
    VOTIT
    DON'T FORGET TO RATE;
    10helpful
    4answers
    Remote programing for TV after changing batteries
    HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
    1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
    1helpful
    Kidz Remote
    RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
    Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
    2answers
    Programing universal remote
    Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
    Top Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
