Bosch Aquasensor Detergent Dispenser door wont open during any of the diswasher cycles
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Daniel
I have replaced the solenoid and it still doesn't open! ANY OTHER SUGGESTIONS....
when running normal cycle the detergent door doesn't open.
The dispenser door is not opening in any cycle. I have cleaned it. It opens fine using the mechanical release. I have observed with the front panel removed and the wax motor never seems to come on during cycles.
timer sticks during cycle. How do you replace the timer control module
The dispenser for automatic release of the detergent does not open
