Ovens Logo
Rachel Barrera Posted on Dec 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pad on oven does not work cant start oven - Ovens
Claude Kayser
Level 3:
Top Expert:
  • Ovens Master 9,098 Answers
  • Posted on Dec 01, 2015
Claude Kayser
Ovens Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067181
Points
28436
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Can the thermostat on a Thermador oven be adjusted ?
you can recalibrate it yes.
https://forum.appliancepartspros.com/posts/t191937-thermador-oven-temperature-thermostat
It's on page 32 of the manual for Thermador's built in convection ovens.
1. turn off the oven
2.touch and hold the start pad and then touch the bake pad
3. 0 (zero) appears in the temp digits. release all pads
4. touch bake and 0 changes in increments. max adjustment is 35 degrees F.
5. to complete change touch start for lower oven on double ovens do this: touch the roast pad instead of the bake pad continue with steps 3-5.
Please always include full 'make model (what it is)' in all questions.
Nov 27, 2021 • Ovens
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 • GE Ovens
The start button doesnt work, but all the rest do, What can it be?
Its a very common occurence for certain buttons to work on the touch pad yet others dont work.The only fix is to replace the touch pad.
Gene
I dont want to use the self clean but I cant get off the baked on grease. What can I use?
Go to the hardware store and get scotchbrite pads that are medium in coarseness. The rougher the better, but not so rough as to scratch the finish. Use powdered laundry detergent to clean on a damp scotchbright pad. Spray oven cleaner works well but has a lot of fumes and is not as kind to hands.
Thanks
Jan 06, 2011 • Bosch Ovens
1helpful
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
2helpful
Exactly the same problem. My oven is 11 yrs old instead of 10
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Oven touch pad not working properly.
Hi. this will only get worse. i would replace this defective touch pad asap if possible.
Maytag gas oven touch-pad control panel does not work proplerly.
you can replace touch pad and not very hard to do,you may want to replace control board also.
Mar 12, 2009 • Ovens
GE JKP27WP1 Built-In Double oven - the start button on the touch pad doesn't work. Everything else works fine. Haven't received an error code.
Try gaining access to the touch pad and, try to free up the start button. if this is unsuccessful, replace the touch pad.
Clock Display
Press and hold the bake and broil pads together for 2 seconds. SF should appear in the display. Press the clock pad, it will toggle between 12, 24, and off for a black display. Toggle to 12 and press start...Catriver..post back.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
