I cleaned around the feed dogs. lots of lint and fuzz. machine clocks and when the clock goes off sewing is good for about 10-15 seconds, then stops and clocks again.
You might try a brand new needle. Perhaps the original is bent or damaged. Also, try rethreading everything from the very beginning.
If you continue to have issues, could be something haywire with the software. May be time for a service check.
Juki HZL F300 Exceed Sewing Machine at Ken's Sewing ...
www.kenssewingcenter.com/juki-hzl-f300-exceed-sewing-machine-p-30...
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Juki HZL F300 Exceed 106 Stitch Computer Sewing and ...
www.allbrands.com/products/22395
$749.00 - In stock
Juki HZL F300 Exceed 106 Stitch Computer Sewing and Quilting Machine +$50 Knee Lift Lever + $50 ... High speed sewing up to 900 spm, stitches per minute
Juki Exceed HZL F300 Home Deco Computerized Sewing ...
This happened shortly after the reverse stitch button and thread trimmer button both briefly stopped functioning (it was for just a few minutes). Then they were working again.
I don't know. The machine was working fine and then all of a sudden stopped and started clocking. I have reviewed the performance check list in the manual and it doesn't address anything other than checking the presser foot and needle, and cleaning under the throat plate which I have done.
