check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
You need to call GE customer care and order the trim you need. Make sure they will ship the replacement guide with the part. Before you do that however, carefully inspect the door to see if the old trim can be easily removed. This is important! You must determine that the door/gasket will not get out of alignment in the process. If this happens, dangerous microwave energy can escape.
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
