Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
Posted on Nov 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch Dishwasher wont drain
Problem is with a three year old Bosch SHY56A05UC /14 dishwasher.
It started with the unit not circulating water through the spray arms. Bosch sent a tech and diagnosed a bad circlulator pump. Returned with circulator pump and replaced. Started unit and had no water coming in. Found that solenoid valve screen was blocked with debris from moving the feed hose around and dislodging debris in hose. Replaced solenoid and water feed hose, flushed out line, re-connected and tested the unit. Water was flowing and new circulator pump was working properly. At that time cancel drain selection was pressed and drained. A regular wash cycle was started and the tech left. After the cycle ended and dried we checked the unit and found water still in the bottom, it had not drained. We put it through the cancel drain cycle and it drained. We scheduled service again. While waiting for service (weeks) we made several attempts to run a full or quick cycle, it would intermitenly work, sometimes it would drain initially when started then not at the end of the cycle. Other times the cancel drain would not work. The tech returned and diagnosed a bad control board and replaced. Tested the cancel drain mode and left. We started a full wash cycle and when it was finished there was more water in the bottom. So it's been 49 days without a dishwasher and factory service another 14 days out and the holiday next week we're at our wits end. Some other points; when you start the cancel drain a noise can be heard like it wants to start.
Any help would be greatly appreciated
John
  • 2 more comments
  • Anonymous Jan 24, 2008
    I have the same problem right now and would be interested in talking to you further. Everything seems to be working and draining properly. The sprayer arms are not rotating, so I am asuming a circulating pump problem more than the control module. You said everything worked after the circulating pump was replaced, other than water at the bottom at the end of cycle? When control module was replaced, did this change anything noticable for you? Let me know what you think! Was it the circulation pump, or circulation motor, or both? Thanks for your advice and help!
    Jeff
  • jni16605 Feb 11, 2008
    Bosch Model SHY56A05UC/14 won't drain during any wash cycle or when
    "Cancel Drain" is initiated. Dishwasher started making an
    inordinate amount of noise during any drain cycle a few months ago but
    still drained. Now it makes the same noticable grinding noise but
    no longer drains. The filter is not clogged. When bypassing
    the door switch during a drain cycle, I can see the impeller turning
    and the water moving but it does not drain. HELP!
    Thanks
  • Anonymous Mar 18, 2009
    HOW DO YOU REPLACE THE DRAIN PUMP?
  • jni16605 May 11, 2010
    How much is drain pump and how difficult is it to get to?
Anonymous
Level 2:
  • Expert 213 Answers
  • Posted on Nov 20, 2007
Anonymous
Expert
Level 2:
Answers
213
Questions
Helped
215627
Points
886
Have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5386
Points
5
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Anonymous
Level 1:
New Friend:
  • Posted on Feb 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5386
Points
Sounds like a blockage. Our 7 year old model has done it for a couple of years.. Take it out turn it over (emptying first) and hope for the best.
Bosch dishwasher shy56a05uc 14
I would assume it would leave water in the machine. some machines have this as a function. it is used to keep water in the drum to stop items becoming excessively creased. it is mainly used if you are not going to empty the machine for a while. you should be able to press the cancel button again to start the draining process.
Dec 13, 2013 • Dishwashers
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
1helpful
2answers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 • Dishwashers
4helpful
My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
2answers
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
2answers
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
