Replace clock / control
To get away with the dim temp light.. till you can get it fixed.. Just remember after you turn on the oven.. If you hit either the up or down buttons.. starts at 350.. goes either up or down depending on which you push.. 5 degrees each push.. So for 375.. 1 to get to 350...then 4 more times... If you loose count, push cancel, bake, up.. you're back to 350... Then order the part cause doing this all the time is a pain.. but works till it's fixed !! Good luck !!
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - 3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board).
Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
