Washing Machines Logo
p
paul hampson Posted on Nov 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
When you run it on a normal cycle , it fills cold,then cleans for about 10 minutes, drains and goes to refil but the pwer then trips off
Claude Kayser
Level 3:
Top Expert:
  • Washing Mach... Master 9,098 Answers
  • Posted on Nov 29, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061527
Points
28436
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
4answers
Whirlpool Dishwasher won't run
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
How to fix my Indiset d41 dishwasher ? The power button trips out the electrics ! Stopped mid programme , wont drain , still water left in it after it flooded the kitchen . Cant try any other programme as...
You have a component down to earth. The problem isn't the start button. Most likely to be the element, but ciuld be wash or drain pump. Check the element with a resistance meter first, when you find the componant at fault, replace it
1helpful
When I pull the red lever on the electic mower, the lawnmower will not start and the GFI to my house is being popped?
just for a quick test -- run power to the mower using a different outlet,,, GFI outlets are well known for having a bad trip circuit in them,, they go bad all the time. so if your mower does in fact work on a different outlet with no problems then the issue is your GFI outlet and you will need to replace it.
if the mower is infact tripping the next circuit then the problem is with the mower motor windings or a short at the switch or two wires shorting out. check all wires and make sure connections are good.
c...
I have an electric Kenmore dryer that wont turn on
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
1helpful
2answers
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
2answers
NO POWER TO THE MACHINE
Hello. I can help you. Since you already checked out the power, skip that step and look at the latch.
Door switch
Wiring
2helpful
Iron tripping my electric
Check the power label on the unit to see if it is indicating a higher requirement than what your circuit breakers and house wiring is rated for. I have seen some professional equipment indicating 20 amps, and the house power was rated to 15 amps maximum. In this case an electrical contractor had to be called in to replace the wiring and and circuit breaker to meet proper specs. This is expensive!
If the unit is rated under the house power available and the breaker is tripping, then there is obviously a defect in the device and service is required. I have seen heating elements go partialy shorted, or there were thrmostat faults and the device was overheating.
Jerry G.
Dryer will run in cool down mode,but not in any other.
Hi!
Please check the following---
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please accept this solution and ask for any clarification.
Thanks
Rylee
9helpful
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Top Washing Machines Experts
john h
