Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
m
michael belt Posted on Nov 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Are there a reset button on the motor - Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
David Smith
Level 2:
Scholar:
  • Expert 120 Answers
  • Posted on Nov 28, 2015
David Smith
Expert
Level 2:
Scholar:
Answers
120
Questions
Helped
20256
Points
316
No, but there is a thermal fuse, normally located on the blower duct, near the blower wheel. More than likely, that's the issue if it doesn't start.
Testimonial: "WOULD THAT THERMAL FUSE MAY HAVE BURNT OUT"
2answers
DC Blue and PLUS reset ? remote lost, connect new but memory full
If you have lost your remote for your DC Blue and PLUS garage door motor and need to connect a new remote, but the memory is full, you will need to reset the motor to clear the memory before programming the new remote.
To reset the DC Blue and PLUS motor, follow these steps:
  1. Locate the reset button on the motor. It is usually located near the bottom of the motor and may be labeled "Reset" or "Learn".
  2. Press and hold the reset button for about 10 seconds until the LED light on the motor flashes rapidly.
  3. Release the reset button and wait for the LED light to turn off. This indicates that the motor has been reset and the memory has been cleared.
Once you have reset the motor, you can program your new remote by following the instructions in the manual. If the memory is still full and you are unable to program the new remote, you may need to delete some of the stored remotes from the motor's memory to make room for the new remote.
To delete stored remotes from the motor's memory, follow these steps:
  1. Press and hold the "Learn" button on the motor for about 10 seconds until the LED light starts flashing.
  2. Press the button on the remote you want to delete from the memory.
  3. Wait for the LED light on the motor to flash rapidly, indicating that the remote has been deleted from the memory.
Repeat these steps for each remote you want to delete from the memory until you have enough space to program your new remote.
If you are still having trouble programming your new remote or resetting the motor, you may need to contact a professional technician for assistance.
How do you reset the overload switch
An electric motor used in lots of equipment may include overload reset button on the motor body. If the motor is overloaded or if it overheats, this button will pop "out" indicating that an internal electric safety device has tripped,shutting the motor off.
Once the motor has cooled sufficiently it can be re-started, usually by pushing the popped-out reset switch back down.
Eureka Airspeed Unlimited Pet Vacuum need to find reset button. Looked around & near motor & cannot find. Please help me find?
Ivan say for sure without knowing your model number but it most likely does not have a reset button. Most have a thermal reset belt into he motor because it's cheaper than putting on a reset button.
If i have a bad cad cell and press the reset button would i just get a click
sounds like you have to manualy reset the burner motor. Every north american oil burners have a manual reset button,, tiny little red button located on the sides of the motor, if it needed resetting you should feel a slight click . then reset the primary once again. if youu have an electgrical tester u could always test for 115volts at burner motor upon rsetting primaryt
Where is the.reset button
The reset button is located under the cover visible from the dipstick side of the pump, however, if there is no visible button, then the reset is incorporated within the windings of the motor. The reset hidden in the windings does fail and can be eliminated with much effort. If the motor is cutting out for no apparent reason and comes back on after it cools or if the unit will not power on and all components test good, then suspect internal reset. The internal reset fails if the motor has been overheated many times by low power, or too long of an extension cord or powered by generator.
Reset thermal
I think the question is thermal overload on a three phase motor. If a motor has a thermal overload that must be manually reset then there should be a button on the motor, often red. While the motor is de-energized (power plug removed) , push the reset button by hand.
Jan 04, 2014 • Dryers
2helpful
Reset switch location
the reset button is in the on switch what you need to do is unplug from wall socket then press the on button down hard to reset.
Is there a motor reset button on the whirlpool dryer
1) Sometimes some motor have reset button , other NOT
2) See the w. diagram attached. God bless you
3) Download the instruction manua go www.fitness.manualsonline.com or www. retrevo.com
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
