Computers & Internet Logo
Posted on Nov 28, 2015
My home Belkin network has stopped working. The F5D4077 powerline link LED is displaying a solid red colour. What does this mean? How do I resolve this problem?
5 Related Answers
Mike McWhinney
  • 537 Answers
  • Posted on Oct 31, 2007
SOURCE: D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
A Miller
  • 8404 Answers
  • Posted on Mar 09, 2010
SOURCE: I have two Belkin powerline adaptors 200mbps type
Your hard disk is failing and should be replaced. Have you tried to press F1 when you get the message? If this doesn't help try to enter the bios and disable S.M.A.R.T.
Your first goal is to save the data so please do that before it's too late.
Anonymous
  • 5 Answers
  • Posted on Aug 20, 2010
SOURCE: I have been using my Belkin powerline adapter
Is the same phase used in your office?(electrical wiring)
Anonymous
  • 103 Answers
  • Posted on Sep 02, 2010
SOURCE: Trouble expanding my Belkin Powerline network
F5D4075 uses Homeplug AV standard and F5D4071 used Home plug 1.0 Turbo. Both are not compatible to each other. So if you form a network, you have to form with the same standard.
Secondly, You need just one Powerline adapter on the router and you can have 2 or 3 adapter connected to 1 computer each and all these computers can connect to the 1 adapter on the router. You do not have to use it in pairs
Anonymous
  • Posted on Aug 13, 2012
SOURCE: what does a red light for powerline activity mean?
It indicates your line quality for the Homeplug - Green: Best, Amber: Better, Red: Good
Details here http://www.zyxel.com/uk/en/products_services/pla_401_series.shtml
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Using belkin gigabit powerline adapter with a wirless router
Try to configure the 2 routers to work with one another when they are next to each other using standard ;an cable. Once working the powerline should work fine. If you try to configure them when they are apart you have 2 things that could be causing problems to take out the powerline to begin with, then when they are working close, move them apart
I have had a pair of Belkin Powerlive AV adapters (F5D4072) for a while now and they work really well across my house between two routers. I recently bought a 2nd pair of the newer F5D4074 adapters (old...
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
I have 4 Belkin Powerline adapters, two F5D4074 and two F5D4072. On Belkin website they are declared compatible, but I can't manage to transfer the password between the 72 and the 74, with the result that...
Also try to rest the adapters and reconfigure them again.
2helpful
Belkin powerline adapter doesnt connect to internet
try resetting the adapter
if not working try updating the firmware
if not working make sure ur adapter is pluged in the same power(electricity) phase of ur house with the router
the house will have different power phase so make sure of it
both the router and the powerline adapter must be in same phase of electricity
2answers
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
