Question about Dyson DC59 Animal Bagless Cordless Stick Vacuum
Not holding the battery charge keeps cutting out
Dc44 animal keeps cutting out after little amount of use, always in charging dock maybe battery use by date is up only a little over 1 yr old
You shouldn't leave the battery on charge all the time. Only charge when it needs it. You have most likely exhausted the battery life.
Sep 06, 2017 | Vacuums
Why does my dyson DC59 keep cutting out
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleanerkeeps cutting out. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 30, 2016 | Dyson Vacuums
Dyson DC44 Animal Handheld Vacuum, keeps cutting out
dyson-dc44-animal-handheld-vacuum-keeps-ehecv3x4uj13pgwprhzrjmma-4-1.jpgThe battery falls slightly loose, so you have to fasten it securely to the body of the vacuum. I learned this from another user here on Fixya. He uses electric tape. I used one of those rubber bracelets that kids wear. Worked perfectly!
Mar 10, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
DC44 Animal Cordless Vacuum power cuts on and off while trigger is pulled
This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to work...total PIA
Dec 17, 2012 | Dyson DC44 Animal Cordless Vacuum
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a unit that is about 4 years old and appears to NOT hold a charge. I know to only charge for 3 hrs max but want to be sure my problem is the $75.00 battery before I purchase one. What is your...
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Mar 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
Nov 15, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Not holding charge
Ok, folks.. I just posted my own problem with the battery not holding it's charge..but, we fixed it ourselves.. take the motor loose from the canister , remove the filter and in the back are two contacts.they are two screws at the bottom one on each side... get out your pencil with a GOOD eraser and clean those contacts!..clean around them both and the contact (silver spot at the bottom) and you're good to go!!
May 29, 2007 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC59 Animal Bagless Cordless Stick Vacuum Logo
301 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Gerry Harvey
Gerry Harvey
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
