Refrigerator Adjusting Temperature Controls. At initial startup both fresh food and freezer controls should be set at the normal setting or mid point settings. Temperature controls can be found in the back of the fresh food compartment, near the top of the fresh food compartment, or on the dispenser panel.
Feedback
Refrigerator Adjusting Temperature Controls - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId...
Refrigerator Temperature Control Dial - What Do The ...
removeandreplace.com/.../refrigerator-temperature-control-dial-what-do-...
Mar 4, 2015 - The more food you have in your refrigerator, the more stable thetemperature will be. Set the thermostat to the middle of its range and leave it for ...
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
Hope this would help you.
Have a nice day!
