Net10 ZTE Whirl 2 No-Contract Cell Phone Logo
Miriam Unangst Posted on Nov 28, 2015
How to fix unresponsive ZTE Whirl 2 Z667G touch screen
MY ADROID TURNS ON BUT WHEN i TOUCH THE SCREEN I GET NO RESPONCE
Zte n910 is locked need to hard reset for zte n910
Warning Hard Reset will erase everything on your Device !
You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everything.
How can i fix my screen so it can recognize touch? everything works except i cant actually touch the screen
what have you done so far to get it to recognize touch? I have the same phone and was wondering what you may have done.
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
1helpful
MY TOUCH SCREEN ZTE GROOVE MUSIC DOES EVERYTHING BUT THE SCREEN WONT WORK HOW DO I FIX IT
Mine Does The Same Thing I Am Trying Everything Letting Get Air And All It Still Wont Work I Really Need this Phone And My Screen in Black CANT SEE ANYTHING its a ZTE GROOVE PHONE
2answers
Sprint zte fury touch screen unresponsive..any solutions?
Your touch screen didn't like "touching" your "really sweaty" chest! Te oils from perspiration are playing havoc with the screen. Use some rubbing oil on the screen with a soft cloth to remove the oils.
My samsung sch-r710 touch screen is unresponsive. Will a hard reset fix the problem? How do I perform a hard reset?
try to calibrate the touch sensitivity setting before you reset it this always work in any case.nno need to to do a hard reset
1helpful
Instinct phone with screen completely unresponsive to touch.
if its been water damaged or anything like that to where the screen is even cracked or scratched touch phones are very sensitive and yes it might need to be replaced.
10helpful
3answers
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Top Net10 Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Net10 Cell Phone Expert? Answer questions, earn points and help others
