HP Compaq FP5315 15" LCD Monitor Logo
Titus Ruguchu Posted on Nov 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Identifying value of zener diode zd984 on print side of power supply unit
The zener diode i suppose is shorting and has to be replaced. Alternatively an equivalent power supply unit if any .Thanks.
goneforever.
Level 3:
Top Expert:
  • HP Master 14,531 Answers
  • Posted on Aug 01, 2017
goneforever.
HP Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263904
Points
66315
1Nxxxx
you dont have the schematic, and need it (or a B.O.M.)
you wont find one, i bet.
to know what they used.?
find that and know.
you can't measure yours its bad.
measure, a good FP5315 ? nah. that be impossible but works.
learn that many parts are sold under contract to HP.
so do not have 1N (prefixes)
btw the volts and watts must match,
i guess you never used EBAY? (a 1 second look and bingo)
http://www.ebay.com/itm/Compaq-FP5315-Monitor-Power-Supply-Board-6832135600-01-PTB-1356-/222590607854?hash=item33d36f21ee:g:ZJwAAOSwggpZdEFV
tell me how can you get legacy parts (a PSU) any other way>?
parts not sold in any store on earth, answer EBAY.
why not upgrade for far cheaper.
$60 start new, ( and far better to)
https://www.walmart.com/search/?cat_id=0&page=1&query=computer+monitor&sort=price_low#searchProductResult
or at use PC shop find one for $10 working
https://www.shopgoodwill.com/search/SearchKey.asp?itemtitle=computer+display&showthumbs=on&buynow=off&sortBy=itemEndTime&sortOrder=a&closed=&sellerid=all&srchdesc=&month=&day=&year=&days=0&itemSellerStore=
each store has its own used Devices... go there look , get.
kj henriksen
Level 2:
Sergeant:
Habit-Forming:
  • Expert 194 Answers
  • Posted on Jul 31, 2017
kj henriksen
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
194
Questions
Helped
37659
Points
504
1 Related Answer
Joseph Wright
  • 1729 Answers
  • Posted on Nov 17, 2013
SOURCE: Power supply damaged, Can I replace it with any other model power supply?
A standard ATX PS won't fit in your low profile case. The plug types can be different too. Usually there's a schematic with a PS that describes the wire color of each voltage. So you could conceivably shove the pins out of one PS plugs and insert them into the different plug, or solder the wires to the correct pins, and leave the PS outside of the case.
On the power supply unit for compaq fp5315 model pe1233, what value is the zener diode zd984 on the print side of the power board?Titus.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, or the IC number used in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
What the voltage value of zener diodes? (D825, D826 red,red,gray) and D823 (red,yellow).
This table is the information used by MOST diode manufacturers that use color banding on diodes. Most manufacturers stamp the ID right on the diode but some do use color banding as the method of identification. For purposes of alignment, the side with any color band closest to either side of the diode is the equivalent of the left side of this table. The three examples in the table when associated with the values in the lower table, are identified as 1N64E for the top diode, 1N452G for the middle diode and 1N4762 for the bottom diode.
See the color coding
25789975-o5icj23xic0ud0c1fg3qznri-3-0.jpg http://electronicshelponline.blogspot.com/
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
1helpful
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
2helpful
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
1helpful
LG 32lh200 power supply failure common problem
You might try to follow the diode back to the source and read voltage to know the value of the diode and also look on the diode for generic number--short of that Google the model number with "parts" as it might be cheaper to replace the board than try to fix it by guessing values.
Polaroid 860-AZ0-GF371H Power Supply Unit. After replaceing all bad caps and and shorted fets Q102,103 I still need to know the value of smd zener ZK2 in Parallel with 3 low value smd resistors. I think...
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Tv working fine, then suddenly,pop and black screen, sound is ok
The issue here is that the zeners in question are merely like a safety fuse and replacing them before identifying and fixing the cause of the problem will only cause your replacement zeners to blow aswell.... personally if it is a true plasma it likely chews through alot of power anyway so I would take the opertunity to replace the TV with a newer much less power hungry led TV and in doing so save the hip pocket and the environment.
4helpful
5answers
AKAI MLT168A Power Supply
If I give you the values of Z3, Z4 and Z5, would you return the favor by telling me what are the values for R104, R106, R107 and C17?
I have posted this request 5 times for 2 months and no body gave me an answer. Would you be willing to work with me? E-mail me [email protected] and use MLT168A-fixya as subject
Thanks
1helpful
5answers
Tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
-GR
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
