Question about KitchenAid Coffee Makers & Espresso Machines
KitchenAid Artisan Pearlescent Metallic Grey Burr Grinder Ref: 5KCG100BPM motor spins but burrs don't move
- where might the problem be in the transmission - it's all just been cleaned & nothing trapped in burrs, motor spins at high speed but the mechanism to turn the burr spindle fails to rotate - any ideas? Thanks!
4 Suggested Answers
6ya staff
SOURCE:
bansheracer
  • 1089 Answers
SOURCE: Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Posted on May 26, 2009
Anonymous
SOURCE: Motor revs but grinder does not engage.
I am what you would call an expert when it comes to Baratza repairs.
The problem you are describing is not an unusual one. It sounds like the main drive gear has been stripped due to something foreign (likely a stone) sneaking into your grinder with the beans. It would have jammed the burrs, and because of the powerful torque from the motor, the drive gear has been stripped so it will no longer (or rarely) engage the burrs.
To solve this problem you will need to contact COAG Ltd (if you live in Canada) or Baratza if you are from the US. If you machine is still under warranty (less than a year old) this repair will be free of charge and you shouldn't be parted from your grinder for long.
I hope this helps anyone who stumbles upon this and finds themselves with the same problem.
Kind Regards
Emily
COAG Ltd.
877 477 3849
Posted on Jul 21, 2009
Rob C
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Dec 21, 2015 | Coffee Makers & Espresso Machines
No grinding
try check those blades? maybe, its loosen up..if it does,refit it but be careful you might injure yourself.
Jan 24, 2008 | KitchenAid A-9 Electric Burr Grinder
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Kitchen aid burr grinder adjustments
You are correct, the grider positions are locked internaly so the grinder will not go too fine since this can damage the blades and also too fine need more power from motor and also can block it by rottating normaly. However you ir open the grider you can overcome the lock and udjust so the grinder can grind more fine coffee. In order to be always at the safe side just move gradualy step by step until you find the perfect grinding and adjust so that will be the minimum plus one mor move for furure adjustment if you need.
Just for reference the corect grinding is for 7 to 7.5 gr of coffee the running time of the coffee from your machine should be 25 sec for 25 cc of coffee aprox.
Good luck.
Rember to vote for this answer.
Mar 02, 2010 | KitchenAid KPCG100PM Electric Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
241 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
graybeard32301
Ismael Rodriguez...
Marvin
Marvin
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
