DODGE RAM. (per OBD2 is OBD1 dodge unique) USA LAWS.
all plugs dead, we check them all. not just one.
USA spec car? v10.
learn that all ECU/PCM cuts fuel if the ECU detects lost spark
it cuts fuel so spark is first, on all spark plugs
are the plugs over 100k miles old?
ASD WORKS LIKE THIS IF ECU SEES SPARK DEAD ECU DISABLES THE ASD, THIS PREVENTS CRASH AND BURN AS SEEN ON TV.
ALL FUSES GOOD RIGHT> WE TEST THEM.
KEY ON CEL MUST GLOW, THIS KEY ON EVENT IS THE LAMP TEST. IT MUST GLOW ONCE AND CAN GO OUT. AFTER.
IF NOT THE PCM LOST POWER, CALLED BLOWN FUSE.
THE CURE IS BASED Purely off ASD dead.
on all cars Chrysler. even jeeps,
The PCM seens any thing dangerous ASD drops
or even fails top close;. once
my guess is you do not know how to test fuses?????
there are 3 tests, in increased value.
1; gander at it ,looks blown it is. but looking good can be bad.
2: Ohms test can lie if hair line cracks here. but is great test.
3:live test, 12vdc, key on , both sides of fuse 12vdc is good
12 vdc in, and 0v out is a bad fuse (or bad fuse and shorted load)
nothing on earth bets a live test, pass /fail .
learn now the CEL lamp works key on (self test)
learn too how to do THE SM book ODB1 CEL code flash test.'called then Diagnostic jumper.
https://eautorepair.net/Marketing/Default.asp
in 1995 USA this ECU has DLC connector, that has jumper pair of pins called Diagnostic, test.
quote
When the CHECK ENGINE light comes on and stays on (after start-up), this indicates that a code (or codes) has been stored in memory. To retrieve this information for purposes of troubleshooting, cycle the ignition switch
ON-
OFF-
ON-
OFF-
ON within five seconds. The check engine lamp will then
flash the DTC(s). Each code, if there is more than one, will be preceded by a four second pause, to distinguish it from the previous code. An example of a DTC would be as follows:
- Lamp on for two seconds, then turns off.
- Lamp flashes four times, then pauses, then flashes one time.
- Lamp pauses four seconds, then flashes four times
- Lamp flashes seven times.
- code 47, per SM.
codes 43 is ASD relay is dead. bad
code 43 is any bad spark coil , kills ASD dead.
53 dead ECU
54 cam sensor dead., code 11 is crank sensor dead.
63 dead ECU
55 = end of report
Unit is now operating although the right channel heatsink warms more than the left. Found emitter voltage on right reading 29.7 mV, and the left was at 7.3 mV. DC off set voltage on left was 31 mV, and on the right channel it started cold at around 123 mV and after 20 minutes running was below 20 mV. I have POTs VR 1,2 and 3. Does someone have a SM I can download or the adjustment procedure for this NADY SPA 1400 amp?
