You need to check the wireless settings of your router.
settings saved on this computer do not match the requirement
If you connect with a cable to your Router and access the control pannel you should see what is the SSID (name of your Wireless network ) of this routeur.
If you can not do that , while the router is in function check the available wifi available with your portable laptop or tablet , it should be the strongest signal since you are close by. To make sure it is the right one , shut down the routru and recheck with your laptop to seee witch one has dissapeared from the list available
