[PDF]CARESCAPE™ V100 Vital Signs Monitor - GE Healthcare
www3.gehealthcare.com/...monitoring/monitors/gehc-serv...
GE HealthcareNov 21, 2011 - NOTE: The information in this manual applies to CARESCAPE V100 Vital Signs Monitor ...... PULSE VOLUME indicator: flashes to indicate you are making a change to ...... monitor is set to or reverts to factory default settings.
SOURCE: I have GE XS Stereo Commercial Skip Model 27GT619
This information is from the User Guide that came with our set. Good Luck.
2. Skip this step
3. 0 Exit
SOURCE: how do I put the GE remote xs stereo monitor into
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
