SOURCE: Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
SOURCE: Printing on templates
This is normally set through the page margins within the software you are using not the actual printer settings. MS Word has templates for various Avery labels, but I've found after loading the template you have to fine tune the margins for your printer. Use plain paper to print test pages and hold them over your card stock to check alignment.
SOURCE: Printing Business Cards
My problem with alignment was caused by the printer being set to the wrong paper size (A4 not letter). This may not be a solution to the first problem.
SOURCE: want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
SOURCE: Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at
http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
